Autor Téma: 42056 - Porsche 911 GT3 RS  (Prečítané 53738 krát)
  • Príspevkov: 4455
Re: 42056 - Porsche 911 GT3 RS
« Odpoveď #105 : 03. Jún 2016, 13:48:00 »
Zaujímavé je, že ak to má byť chyba v návode, že neradi 1-2-3-4 ale 1-3-2-4, tak koluje vyjadrenie že tak to má byť a je to navrhnuté ako chcú
http://brickset.com/article/21758/lego-responds-to-instructions-issue-in-42056-porsche-911-gt3-rs
Ale celé sa mi to nezdá, tak na jednu stranu to inak nejde, ale zas napíšu, že tí čo si chcú tie kolečká prehodiť nech tak spravia.
Thank you to all our dedicated fans for the comments regarding the GT3 RS by LEGO Technic.
It is correct that the gears in this model are not sequential as in the real Porsche PDK. This is however, a deliberate decision taken to ensure that we make the best possible LEGO version of this amazing car that both meets our design requirements and gives everyone a great building and product experience.
It was a considered decision taken during development that the gears running in the correct order meant that it did not result in a great experience when driving the car. Too many gears are engaged at the same time and smooth running with all those tolerances is just not possible.
If you switch the build in steps 267 and 269 the gears will run sequentially, and everyone who feels that this is the better solution should feel encouraged to do so.
LEGO Technic really is the ultimate open source design product and now that it is finally available, we look forward to seeing all the ‘improved’ models our fans create. After all, that is what LEGO building is all about.
We hope everyone will have a great building experience and feel a strong sense of pride from creating both our version and their very own LEGO Technic representation of a Porsche GT3 RS. We are very fortunate to have such skilled and dedicated fans that can spot this small deviation from reality and would like to thank everyone for sharing their ideas and expert knowledge.
  • Príspevkov: 2029
« Odpoveď #106 : 03. Jún 2016, 13:59:27 »
tak toto je ina fraska :-)
  • Príspevkov: 569
« Odpoveď #107 : 03. Jún 2016, 14:31:53 »
poriadny trapas.. vrcholny model sezony a hned ho musia stiahnut..
« Odpoveď #108 : 06. Jún 2016, 14:24:26 »
lol, no pekne. Taketo nieco sa uz niekedy stalo? Chyba v navode pri Technic sete je dost brutal. Este pri nejakych mojich hradoch je to nic, to nevadi.
  • Príspevkov: 784
« Odpoveď #109 : 06. Jún 2016, 18:05:49 »
Studovanie navodov (akychkolvek - nielen LEGO, napr. navody od papierovych ci plastovych modelov) len tak pre zaavu je mojim hobby odmalicka... Mam skompletizovanu TECHNIC zbierku od roku 2003 dodnes a od vacsiny setov poznam navody celkom podrobne (samozrejme nie naspamat) a urcite by som si spomenul na minimalne 5 chybiciek... vacsinou sa vsak jedna o malickosti, ktore pre stavbu modelu nemaju zasadny vyznam... najznamejsia pochadza z traktora 8284, ale nasiel som chyby aj v setoch 8297, 8295, 8674, 42025 a dalsich... Schvalne neprezradim viac, ci niekto skusi pohladat  >:D
Tak vyznamnu konstrukcnu chybu ako tu na Porsche som vsak este nikde neobjavil...
PS: pisal som recenziu na set 42025 - jednu chybicku v navode som tam spominal....
« Odpoveď #110 : 07. Jún 2016, 19:09:33 »
Aktualna info od TLG:
Krabice Porsche sa nicili vdaka vahe pri preprave postou. Preto je zasielanie tychto setov pozastavene a pracuje sa na rieseni problemu. Avsak LEGO Store su zasobovane aj nadalej.
  • Príspevkov: 760
« Odpoveď #111 : 07. Jún 2016, 21:20:57 »
Ja neviem ale mne sa vobec to Porsche nepaci keby to naozaj urobili racej v Creationari vizeralo by to potom naozaj lepsie. Aspon vidim  aktualitu slovenskych penazeniek ;D
« Odpoveď #112 : 07. Jún 2016, 22:12:49 »
Matej, ja Ta zabijem! ;D  Som cital ten Tvoj prispevok v autobuse, som mal co robit aby som nevybuchol smiechom! Mi hubou tocilo, ludia kukali ci som kompletny! ;D Chcel si napisat CREATOR a nie CREATIONARY.  ;D Z CREATIONARY by to Porsche vyzeralo trochu inak... ;D ;D
  • Príspevkov: 784
« Odpoveď #113 : 08. Jún 2016, 08:13:35 »
(Odkaz na prílohu)
 (y) (y) (y)
Prihlásený MiKeL
  • Príspevkov: 2499
« Odpoveď #114 : 08. Jún 2016, 14:29:49 »
Takze najblizsie hrame creationary tak, ze sa nebudu tahat karticky, ale kazdy sa pokusi napodobit nejaky set a zvysny musia uhadnut ;) Ale o porsche sa uz nikto nebude pokusat, to by uz uhadli rychlo ;)
  • Príspevkov: 4455
« Odpoveď #115 : 08. Jún 2016, 17:10:15 »
Zoznam uživateľských MODov na EuroBricks sa rozrastá
http://www.eurobricks.com/forum/index.php?showtopic=133743
1. už v 5. kroku nahradenie konektora 2 Bushmi znižuje trenie a sekanie prevodov - podstatná zmena
2. zmena orientácie dielov v mechanizme pádiel znižuje protiťah pri vrátení pádiel a tým šancu, že zostanú (polo) zaradené dva prevody - podstatná zmena
3. úprava znemožňujúca radenie "dokolečka" - zmena k realizmu
4. prehodenie poradia pomerov prevodo do vzostupného 1 -> 2 --> 3 --> 4   - zmena k realizmu
5. pridanie kolečka na externé zatáčanie - zlepšuje hrateľnosť (pre veľkorukých  ;) )
6. blokovanie viacerých rýchlostí pri zaradenej spiatočke - zmena k realizmu
7. ľahšie oddelenie karosérie - zmena na ľahšie prezentovanie skrytých mechanizmov
« Odpoveď #116 : 08. Jún 2016, 20:15:17 »
To tam je az tolko nedokonalosti??? :o  To by som od takeho dokonale_sa_tvariaceho modelu necakal! A tie rychlosti radi teraz ako? Som myslel, ze normalne 1-2-3-4. Na ambasadorskom fore to niekto vyhodil na oci jednemu managerovi a ten sa skoro urazil, ze co si to dovoluje, ze dizajneri spravili co sa dalo. ;)
  • Príspevkov: 760
« Odpoveď #117 : 08. Jún 2016, 21:16:39 »
No vidis uz som sa vratil v plnej sile :D :D. Musim niekedy prist do BA stretnutie dat zahrali by sme CREATIONARY este som to nehral ale ako vidim je to super hra.
P.S. Kamarade este sa priznaj ze si mal FIREMNE tricko :D tak to urcite ludia pochopili. ;D
« Posledná zmena: 08. Jún 2016, 21:18:28 od matej »
  • Príspevkov: 989
« Odpoveď #118 : 08. Jún 2016, 21:23:42 »
To aby spravili zvolavaciu Akciu na tie Porsche...  >:D Dnes je to moderne, ved v koncerne VW je to na dennom poriadku...  ;D Momentálne ale riešia zvolavacku na 400 000 ks Cayenne tak neviem no...  ???
  • Príspevkov: 4455
« Odpoveď #119 : 08. Jún 2016, 23:01:18 »
Inak obsah po zadaní kódu je len pár posterov a wallpapers. A certifikát.
Ale niekomu sa podarilo zistiť, že ak zadáte nasledovnú adresu, na chvíľu tam preblikne stránka s postermi. Ak sa vám podarí zastaviť preskočenie na stránku s kódom, tak sa postery dajú stiahnuť aj bez neho  ;)
http://www.lego.com/de-de/technic/codebreaker/download-poster
